LOL 0
Wow! 0
I stack mine with a blue breaker style pedal.
Check out Chris Buck's video where he shares klon settings from famous players at 5:20
flanging_fed “
Not decided how I will use it yet, got some experimentation to do.
https://borrowedtime2.bandcamp.com/
Tube screamer mini after.
Boss Sd1 before
Ds1 after
Dod screaming blues after.
All work well .
Tonight I will try the Thorpies
I must dig out the BYOC pedals I built and try them.
True North Tweed Drive
Fulltone Fulldrive 3
EQD Special Cranker
BOSS BD Waza
Gain 10pm
Treble 1am
Volume 11-1pm
It works as a straight boost into the next OD/District, but a bit of its own gain really gives a lovely effect, some brightness and a smooth sizzle, if that exists in your ear-brain descriptions
Zentara after Thorpies you need to be careful with settings as you can get a case of flub out.
Favourite was into the Peacekeeper.
The surprise was when I dug out the BYOC British overdrive (Bluesbreaker I guess) and the Distortion + again the Zentara driving into the others was best. I could even have all 3 on which is more gain stages than I would normally use but sounded great. The Brit was the best of the 2 for me.
I literally had my Les Paul>Bad Monkey>Tweed amp and I was getting clean Marshall tones and it reminded me of tone from Ain't It Fun by Guns n Roses.
flanging_fed “
Next up into Tonex one.
