I hope it's alright to post here (being a drum machine rather than guitar amp) but I'm seriously stuck and know there are a few very knowledgable individuals on here that might be able to help!)
I'm attempting to repair a Roland R-70 drum machine. I bought it at a flea market in supposedly "full working condition", though when getting home and testing it found the headphones output was very weak and no audible signal from the stereo L/R outputs.
I've tried to fix it with the help of GPT but it's confidently sent me down numerous rabbit holes and consistently provide incorrect advise, so I'm reaching out for some real human help!
I've so far replaced the following capacitors:
C2, C5, C7, C10, C11, C12, C13, C16, C32, C33, C34, C35, C36, and C50. This significantly improved the headphone volume, but the stereo outputs are still silent. The screen and main sounds/program is all running as it should and working perfectly through the phones output so I'm convinced it could be a relatively simple fix.
Service Manual PDF: https://www.synthxl.com/wp-content/uploads/2019/05/Roland-R-70-service-notes.pdfGPT was pointing me to IC42 being the problem but I'm not convince this is correct. Any advise would be hugely appreciated and I can provide multimeter readings of anything that might be helpful.
Cheers!
