It wasn't too difficult because the body of the organ could come apart so you could take it out still in its 'frame', so I just had to build a box around it. I made a basic control panel by drilling an aluminium plate and attached components to that (jack input, on/off switch, speed switch, power input and switch). I wasn't confident about the electrics so an electrical engineer I knew at the time told me what to put on the control panel and then he finally wired it all up.
It works fine and I've used it for recording, and I feel good that it didn't get scrapped. It doesn't include an amplifier so you have to plug an amp in to drive it (I've got a little 5w head I use for the purpose.). Obviously I didn't have to build any of the rotating speaker mechanism which is the complicated bit.
I'd love to get in touch! Will ping you
The speakers are stationary and project into the top horns and bottom drum.
The Yamaha ones do have whizzy speakers in the top section. Those look like **great** fun
Some do have an actual speaker that spins around though. My one (which I mentioned above) is one of those. The wires plug in to a special socket which is where the speaker pivots round. The plug socket spins so the speaker wires stay put. You can see in this picture the drive belt and where the wires plug in:
But really it’s more about having a fun project as it is about needing the effect and needing to do it practically instead of with a small pedal
Making stuff is good for the soul
Everyones favourite Eurovision failure has done a few videos on them.
Reading this thread makes me think about reviving the idea ... wonder how else you could make the drum?
The old single rotor internal version that was used in home organs use a moulded polystyrene drum, at the firmer end of the material but very light. And I think some of the standalone versions like the Fender Vibratone used the same. I wonder if a 3D printed material might be on the heavy side - I'd almost be inclined to try making the drum from something like a foam insulation board material stacked up to the necessary thickness with the scoop carved out, and perhaps something applied to the inside of the scoop to form a harder, more reflective surface.
Easy-peasy!
Might actually work?
