LOL 0
Wow! 0
I had already looked over the joints in daylight but I went over again with my phone torch because it’s darker now and the heavier shadows revealed some weirdness
I’ve checked voltages at all the test points and valve pins and all seems fine
At least the other repairs were worthwhile too!
The main thing that’s bugging me is how many screws you have to remove to get at the valves.
The valve cover should be held on with four ‘thumbscrew’ type bolts, or if that doesn’t comply with safety regs now, four large-diameter screws that aren’t so easy to chew up or lose.
