Potential major U-turn here. For years I’ve used multi-channel amps.
Playing everything from funk/reggae to Americana to proj rock / metal and most things in between.
I’ve used 2-4 channel amps, and used a Kemper for years with flirtations with the AX8 and QC.
But recently I’ve realised that some of my favourite tones are boosts / drives over a clean channel.
Tumnus mini, Keeley DS1, CM Plexitone…
I do prefer smaller amp heads as I’m old / lazy.
In my reggae days a Fender Twin in a festival back line was glorious. But I also got lovely cleans from my TSL122 (before it died a long and drawn out death) and nice low gain crunch from its second channel too.
Both back breaking amps.
So I’m now considering a single channel amp with v flexible cleans, but not ruling out two channels or other approaches.
A massively open ended discussion but what do you guys think.
Thanks
Andy
Or buy my Marshall ST20 stack, great pedal platform, not too heavy, sounds lovely and looks cool too.
Petepassion - Trading Feedback Discussions on theFretBoard
If I wanted clean, small and portable I’d probably look at a Revv D20 (? the Fender-y one) or maybe the PRS HRDX 20 which can be an utter bargain and a different flavour. The Bad Cat heads are great too and fairly modest in size and weight.
https://thefretboard.co.uk/discussion/295488/fs-laney-lf-supertop-head-matrix-nl112-matrix-nl212
If valves are a must, the Ceriatone OTS 20 I'm selling in the classifieds also has stellar cleans and is worth checking out. It has a built in boost as well and some interesting voicing options.
The Hampstead Artist is also amazing as a pedal platform but is a fair bit larger and a lot more expensive.
The V40 is a good shout. Single channel, easy to get a great clean tone, and fairly affordable used. It’s quite a dark sounding amp though, like most, if not all, Victory stuff. Takes pedals very well and sounds good at home volumes too if that’s a concern.
The gain channel and modes...yes, needs a different approach, using ears not eyes to set the controls.
Fairly light weight for a head, simple single channel and plenty loud if you need it to.
