Nines are not for me..
RockerRocker Frets: 5479
I tried a set of EB nines on my Telecaster and am more than surprised at how hard they are on my finger tips than tens which are on my other guitars.  There is only one (thousand of an inch?) of a difference but it is noticeable.  Not something that I expected…
Nil Satis Nisi Optimum
«13
  • koneguitaristkoneguitarist Frets: 4577
    I use 8’s on a tele, used to use 10’s mainly for about 35 years.
    i found I had to adapt my playing and use a thinner pick, but prefer it now.
  • stickyfiddlestickyfiddle Frets: 36263
    I love 9s on Fenders.
    I fairly heavily dislike Ernie Balls though
  • OffsetOffset Frets: 22190
    edited May 30
    ^^100%.  Or to be precise, 9s on 25.5" and 10s on 24.75".
    A guitar I bought recently had EBs on it and they were fucking horrible.  Felt tight, stiff and difficult to bend.  I don't know why.  I changed them PDQ.
  • blobbblobb Frets: 4062
    I think it comes down to tension more than it does diameter, try some Newtone strings.
    Feelin' Reelin' & Squeelin'
  • SquierDudeSquierDude Frets: 19
    I’ve used Ernie Ball Super Slinkys since I started out. There’s a reason so many great players endorse them.
  • fretmeisterfretmeister Frets: 31769
    Gauge is a terrible indicator of tension. Metallurgy/construction is a far bigger factor.
    That’s why one company’s 11s can be lower tension and higher flexibility than another company’s 9s with the same tuning.
    Attributed to Albert Camus
    https://kottracker.com/
  • ICBMICBM Frets: 83607
    That really only applies to wound strings. There isn’t enough variation in steel to make that much difference to plain strings, which is where you feel it most.
  • Fishboy7Fishboy7 Frets: 2689
    I find 9s unplayable and also really hated Ernie Balls when I tried them.
    These are my favourite strings for Teles for the last few years:
    https://www.guitarguitar.co.uk/product/241101431637008--stringjoy-signatures-balanced-light-gauge-nickel-wound-electric
  • strtdvstrtdv Frets: 3559
    10's on my guitars that have a 9.5" radius, 11's on guitars with 12" radius and above (all 25.5" scale)
  • PlectrumPlectrum Frets: 823
    I prefer 9-46 over 9-42 but only use then on my 25.5 inch scale length guitars. I use 10-46 on the others.
    "Take the Gibbon from you hair ..."
    I'm sure, but what that reason is I do not know.  Not to my taste.  In fact, horrible.  YMMV.
  • LogieLogie Frets: 577
    Until recently I had a Fraser Strat, USA Tele Plus and a Gibson Les Paul Standard and they were all strung with 10-46’s.
    The Fraser felt like a little more fight to play whereas the Tele and Gibson were an absolute doddle.
    No idea on the scale length of them and in isolation the Fraser was a dream to play but no doubt the Tele/ Les Paul felt a lot easier to play
  • crunchmancrunchman Frets: 12417
    They are paid to
    1reaction image LOL 0reaction image Wow! 6reaction image Wisdom
  • Danny1969Danny1969 Frets: 13308
    Funny enough I tried a set of 9's on my Strat last week after years of playing 10's and had the same experience. The thinner strings cut into my fingers more. So I took them straight off again.
    In the nineties I used 9's downtuned a semi, these days that will feel terrible.
    I've used 10's for years, but have experimented with 9 to 46 on my 25.5" scale guitars in the last few months.  I've got be really careful to pull them sharp.  In the long term, that might be good for my technique as I tend to press too hard, but I'm not sure I'm going to stick with them.  I might just go back to 10s.  If I play bass or acoustic for a bit, that strengthens my fingers anyway so I don't find 10s to be hard work.
  • munckeemunckee Frets: 15126
    I’ve just switched to 9s on my Strat as I bought a 3 pack on here, if someone had just changed them from my normal 10s I would never have known.
  • NeilybobNeilybob Frets: 1983
    I like 10.5 on all guitars. I like to fight it when I play.
    flanging_fed “
  • duotoneduotone Frets: 1546
    Last string change I put 9.5's on my Thinline Tele & I'm really happy with them.
    Felt like I needed a bit more tension when playing chords than the set of 9's that were previously on that guitar.
    I have Dunlop Rev Willy 8-40 on most of mine, even in E Flat.
    8s worked for Hendrix!
    I might get some of their 9s for my LP though!
    edited May 31
    He used Fender F150 10-38, usually tuned down a semitone. F150s were rolled back then, so actually probably closer to 10-46 round wound in tension - unlike modern F150s which are round wound, including the so-called Voodoo Child set. Confusingly, they do still do rolled-wound strings but these are now called Original 150s.
    I don’t think 8s existed until the 70s - although in the late 70s or early 80s Rotosound did 7s and 6s as well!
