Advice please - No sound VOX AC10C1
GomersGomers Frets: 177
Hi all,
After extolling the virtues of my Vox AC10C1 in another thread, mine has decided this morning not to output any sound, through my pedal board or guitar straight into amp input.  I've done the, "am I being stupid ?" checks but to no avail.
Powers up fine but that's it and does make the shutdown thump if any gain/master is up from zero.  Any advice would be great, thanks.
  • Danny1969Danny1969 Frets: 13295
    I serviced a couple of these recently with issues. I found one had a valve hanging out and one had a spade connector that wasn't gripping the connector. And both needed the pots servicing.
    Take the back off and have a look. Be careful as you remove the back as from memory there's wires attached.
  • GomersGomers Frets: 177
    edited June 1
    Cheers, I'll have a look.  I did have the back off it a couple of weeks ago to have a general look around, don't think there were any wires attached from memory.  It has worked fine since then, I might add
    Amp last used on Fri night without issue.
  • ecc83ecc83 Frets: 2034
    Did not know the amp but, all valves, push pull EL84s it seems? No sound but evidence that the OP stage is working, the pop, as is the speaker.
    If not a valve fallen out as Danny says check the heaters are alight in the PI and first valve.
    Dave.
  • ICBMICBM Frets: 83497
    Not quite, there are a couple of solid state gain stages. One is before the gain control, so a problem there is a possibility.
    A loose or failed preamp valve is still more likely though.
    Heaven forfend IC! You cannot mean I have been told porkies on a mnftcr's site? Might the SState supply have popped?
    Dave.
    No, the transistors (FETs, can’t remember which type) run from the same HT chain as the valves.
    As far as I can see they don’t describe it as all valve, it’s very sneaky - they say “a full valve compliment of 2 × 12AX7 preamp values and 2 × EL84 power valves.” They just don’t mention the solid-state bits… which *implies* it without actually lying :).
    Had a quick poke around, when powered up, I can't see any glow from the preamp ECC83 in V2 position.  Valve isn't loose.
  • jca74jca74 Frets: 847
    Try swapping it with the valve in V1 and see if the problem follows the valve or the socket...
  • LPManicLPManic Frets: 1724
    You definitely sure you plugged it in?
  • JeremiahJeremiah Frets: 823
    Just as bad (for the pedants) - this is incorrect use of the word "compliment" - it should be complement.
    That bloody Dent woman gets everywhere!
    Dave.
    Dropped off with the tech, will see what comes back.  I've also asked for all valves to be swapped out if he has stock of decent replacements, they appear to be the factory spec.
    You only need to change them if they’re faulty, the factory ones are fine. If he’s changing V1, make sure he uses a Chinese or NOS valve, it’s a cathode follower and Russian and JJ valves have a high failure rate there.
    Oh !  :s
    Spot on with that thanks, preamp valve kaput.  The 2 EL84s were changed too, matched EH valves, so Russian
    They’ll be fine - it’s the V1 valve which is the problem, the second half of it is a cathode follower. Russian and sometimes JJ ECC83s have a high failure rate due to poor cathode-to-filament insulation - but Chinese ones are fine, as are all genuine NOS (ie western European, not 90s Chinese or Russian!) types.
    If you want to put an expensive valve in it, a Mullard or especially Brimar (which I’ve found less microphonic than Mullards) would be a good choice.
    Is the V1 not one of the EL84s ? https://www.voxshowroom.com/uk/amp/ac10c1_hood.html
  • GagarynGagaryn Frets: 1839
    Odd they have numbered the valves that way. V1 is the first pre amp valve - almost always the one closest to the input jack - V2 in that diagram. Their numbering makes no sense!
    Ah, I forgot that - their numbering scheme makes no sense at all, it’s not even fully backwards with V1 and V2 as the power valves.. V1 in any sensibly numbered circuit is the first preamp valve. I’m guessing it’s this one that failed. Using their numbering, it would be V2.
  • AirmilesAirmiles Frets: 69
    Is this the same issue for which Valvewizard advocates a diode? Or something else? https://www.valvewizard.co.uk/dccf.html
