Tinting Tru-Oil?
fretmeisterfretmeister Frets: 31598
edited June 2 in Making & Modding
I have a Warmoth neck that needs finishing. Warmoth do a quick dip seal so unless I wanted to sand down the entire thing (I do not!) I can't actually colour the wood.
If I go with another Tru-Oil approach, what things are good to tint the oil to be it a bit more vintage amber? Doesn't have to be drastic, just not bright maple.
Would this work:
dartfords Amber Interior Spirit Based Wood Dye - 250ml Bottle : Amazon.co.uk: DIY & Tools
 @stickyfiddle did link a different product in his black strat thread but it's astonishingly expensive in the UK and I'm not going to need a litre of the stuff either!
All ideas welcome!
Attributed to Albert Camus
https://kottracker.com/
  • stickyfiddlestickyfiddle Frets: 36108
    edited June 2
    Mine is General Finishes "Transtint Honey Amber".  Ingredients say it contains: Ethylene glycol monopropyl ether; Diethylene glycol monobutyl ether; Acid Brown 282; Propylene glycol monomethyl ether; Propylene glycol
    I'd be happy to order another small bottle and bring it home but I don't think I'm allowed to take it on a plane...!
    I'd drop Rothko & Frost a line and see what they suggest - I see they carry the Dartfords stuff so will probably know
  • WezVWezV Frets: 20219
    if it's a spirt based stain it should work fine with the tru-oil
  • fretmeisterfretmeister Frets: 31598
    I'll get a bottle of it and try it on a bit of scrap I have.
    And then I'll need to control myself and not order some Chestnut Products Purple Spirit Dye instead.... although that might be cool!
    I think it works best as a light tint for this job, built up slowly over a lot of coats.  I wouldn't try doing a strong colour this way, but it will take the rawness off the maple quite nicely
    I've just ordered a bottle of green and blue chestnut stain. That will be mixed with lacquer though, where it really lets you get a strong colour
    What's the best approach for mixing a dye with tru-oil?
    Do it fresh for every coat or mix up a small bottle of Tru-Oil's worth and then seal it up?
  • RolandRoland Frets: 10582
    Tru-oil solidifies if you expose it to too much air. I’d mix it fresh to avoid this, although this makes it much more difficutl to repeat the same colour.
    Tru-oil already contains a walnut coloured stain. So no problem if you want a deeper orange colour. If you’re going for something else I would use Osmo as the substrate.
    Yeah this.
    I tried to seal a small amount of dyed oil overnight and it had a chunky skin on it by the morning - too much to save anything underneath.
    Thankfully with amber it's quite forgiving to blend slightly-differently-dyed coat over an existing layer
    If you were trying to mix colours it would be a big problem
  • Winny_PoohWinny_Pooh Frets: 9472
    edited June 2
    I did this last month with Crimson amber water based stain and Crimson finishing oil. Stain, diluted 50/50 with water went on with a sponge, maybe a 2nd coat here and there on light areas, blended fine. Then oil on top later with no issues.
  • victorludorumvictorludorum Frets: 1536
    Osmo would work too.
    I am unfamiliar with Osmo and their website doesn't help as I don't know what I'm looking for.
    Which of their products would be the right choice please?
    I like Osmo 3032 Satin. There is also a Glossy version, but it’s not high gloss.
    I used 3011 Clear Gloss
