Hello kind folks, I'm looking for a bit of reassurance.
The effects loop on my Peavey JSX won't engage - I suspected the relay in the effects loop board, changed it out, but no difference - I think maybe the supply to the coil is at fault. Next step I think is to power up the amp and see where the 17V supply is / isn't on the effects board. But, to do this, I need the amp upside down, and don't fancy having it balanced on the power valves. If I power the amp up with no power valves in (at zero volume), is there a risk I could pooch the amp? (I have no intention of sticking fingers anywhere near the dangerous bits, just the effects loop board).
If nothing else works, plan B is to take out the relay and hardwire the effects loop "on", since I never switch it off
Thanks for any wisdom!
Seriously, though… the main issue is exposing the high voltages in the innards, so be careful with that. Taking power valves out doesn’t hurt the amp - but it may unbalance some of the voltages. Does the 17V line come off the transformer or some other part of the circuit?
But yes, it’s safe to power up with no power valves in. But not with no preamp valves, so leave them in - you can damage the filter caps if the preamp valves don't pull down the voltage at the far end of the B+ chain.
However the voltage rise from having no *preamp* valves in can be very substantial at the far end of the B+ chain - from around half the full HT right to the full voltage in some cases - and the caps are sometimes lower spec there, so it’s a very bad idea to pull all the preamp valves and power up.
I always used to just put the amp cabinet face down on the bench and rest the chassis across the back of the cabinet at an angle. That way if it’s a combo you can still easily connect the speakers, reverb tank etc. Even easier if it’s a head.
I think this is the reason the last cap in the chain seems to fail most often in Fender Hotrods - they’re not particularly good caps anyway, but it is noticeable that it fails more than the others. It’s probably in other amps too, I've just noticed it most in those.
