BillDL
Frets: 15528
LOL 0
Wow! 0
The only other change you need is to snip the green and white wires between the two switch terminals, so the resistor isn’t connected to the coil junction.
What I do know is that there are 24 possible combinations of the colours in a four-conductor cable - and someone, somewhere at some time has probably used all of them
You might not need the 470k resistors if you're doing partial splits, though- I've never got as far as using 470k resistors for the coil splits (they're great for single coils) because almost all of my guitars which have splits have a master split for both pickups, but I didn't bother on a couple of HSS guitars I have, because the partial splits darkened the sound enough that I felt I didn't need them.
If you're not doing partial splits with a resistor, though, I could see the 470k resistors being very helpful.
Of course it's probably a lot handier just to try the loading resistors since you already have them to hand, they may well do enough on their own!
I haven't tried that guitar or those pickups but unless the stock pickups are very dark I would guess splits would sound very bright with 1Meg pots! They usually sound bright enough with 500k if you're not doing partial splits...
I had a quick look but I couldn't find a service manual for those guitars (maybe because they're MIJ?). I found what seemed to be more like a user manual, but it didn't give the pot values (you've probably already found that one, lol).
I'm not sure I've tried it but I think @ICBM isn't fond of using a lower value tone pot than volume- it sounds like the tone isn't fully turned up I think. At very least, I don't think it would give an accurate representation of how the guitar would sound with 1Meg pots all round, it would be a bit darker.
I'm not sure what an MIR capacitor is, I tried googling it and got nowhere!
Mylar in resin, probably - they’re normally just called Mylar, although they are in resin. Pretty much all guitar caps in the 80s were either Mylar or ceramic so it’s the most likely.
Anyway, after much experimenting with values I finally landed on 500K Log pots, 0.022uF tone caps, push-pull pots on the tone pots, 470K resistors wired at the switches on the tone pots for impedance matching on the coil split, and treble bypass circuits on the volume pots comprising 0.00047µF (0.47nF) ceramic capacitors and 330 kOhm metal film resistors in parallel. I think it sounds best with these values and although there's plenty treble when needed, it's not overpowering and dials down nicely. It sounds much better than it did as I bought it with the retrofitted 250K pots.
Yeah that's a good call about the MIR.
@BillDL was lucky- when I tried it yesterday Google AI confidently started describing MIS transistors to me! I realise it's pretty easy to hit an "R" instead of an "S", but would I really have typed "capacitor" instead of "transistor" too?
I actually tried it again just to see, and did a bit better this time:
"An MIR capacitor is a specific, robust type of electrical component traditionally built to withstand demanding, high-voltage environments. Historically, many of these high-voltage capacitors were manufactured with chlorinated diphenyl (often referred to as askarel or PCB) oils as the dielectric because of their cost-efficiency and non-flammable nature. [1, 2, 3]
That's AI so no idea if it's right or not! Also I note it doesn't actually elaborate on what the "MIR" stands for so it may well still stand for "mylar in resin"!
@BillDL : I'm glad you posted that pic, I couldn't figure out what you meant by its being "see-through"! I was only thinking of the opaque dark green mylar (?) caps I've come across usually in guitars. But the pic made it clear- I'd forgotten but I think my MIJ Tokai Tele (a more recent one, mid-to-late 2000s maybe?) had a tone cap like that in it (but 0.047uF). Maybe they're Japanese caps?
Not surprised it sounds better with those values, those are basically the "standard" ones which I usually prefer too. I don't really like humbuckers with 250k.
EDIT: Oh, maybe the "MIS" thing I was talking about was a capacitor, not a transistor. I went to Wikipedia (where I should've gone in the first place), and that came up. It has a layer of semiconductor, maybe that's what confused the AI yesterday (or maybe me if I misremembered since I couldn't find the original AI answer from yesterday!).
