FX pedals using batteries
hotpickupshotpickups Frets: 1823
Until I decide on a power supply I'm powering my few pedals by Batteries. I remember rwading ages ago that to stop using the battery power unnecessarily I should disconnect from the jacks cos even though the pedal is off (red light off) it is still using the battery. Is this still true?
  • allicioallicio Frets: 221
    Unless the pedal has a battery cutoff switch of some sort then you do need to disconnect the input jack yeah
    How can I check?
    edited December 2014
    How can I check?
    Tell us which pedals they are
    How can I check?
    Boss TU 2
    EHX Memory Toy
    EHX Soulfood
  • Yes AFAIK they'll all drain the battery if you leave the input jack connected.
    Design fault there then but I guess I realise they are the cheaper end of pedals etc. I'll just have to be careful then
  • For about 20 quid, or less even, you could get a one spot or something similar.
    A tiny bit more and an isolated harley benton power plant junior could be yours. It'll save money on batteries in the long run, and you don't have any complex power requirements :)
    Yes I know of the various power supplies. It's just that Im holding out for the updated version of the Cioks Adam Link which is being launched in March 2015. Just using batteries in the meantime.
  • ICBMICBM Frets: 72822
    It's not a design fault, it's intentional and good design. The purpose is to make it impossible to drain the battery by leaving the pedal switched on with no lead connected. There are very few pedals which don't use this scheme, for a good reason… because it's correct.
    If you want to leave the leads connected (eg on a pedalboard) but still with batteries in, putting a plug into the power jack usually shuts off the battery.
    Can one buy just the plugs then @ICBM?
  • Great for that money I'll go and pick some up at my local branch. Thanks
    Yes. There are a very few that don't - the Zoom G3 is one, it takes power from either the power supply or the battery when both are connected - I suppose I can see the logic, since it means if the power supply fails your sound doesn't cut out if you've kept batteries in it - but it will work with most compact pedals.
    Just check once you've put the power plug in that turning the pedal on and off doesn't make the LED come on and you're good.
  • Sorry @ICBM for maybe sounding a bit dim but I DO want the light to go on when the pedal IS on?
    ICBM;448067" said:
    hotpickups said:Can one buy just the plugs then @ICBM?Yes. There are a very few that don't - the Zoom G3 is one, it takes power from either the power supply or the battery when both are connected - I suppose I can see the logic, since it means if the power supply fails your sound doesn't cut out if you've kept batteries in it - but it will work with most compact pedals.
    [quote="ICBM;448067"]hotpickups said:Can one buy just the plugs then @ICBM?Yes. There are a very few that don't - the Zoom G3 is one, it takes power from either the power supply or the battery when both are connected - I suppose I can see the logic, since it means if the power supply fails your sound doesn't cut out if you've kept batteries in it - but it will work with most compact pedals.
    [/quote]
    But if you put a psu plug in, it should cut out the battery - hence not switch on for storage.
  • Ah so I put the plugs in after I've used them. Now I get it ;)
    Thanks
  • Just tried it and yes it shuts the battery off when the plug is in.
    Thanks for the help :)
