tap tempo tremelo questions
So I seem to have made a tremelo pedal where you set the timing of the modulation by two presses on a tap tempo footswitch. Bearing in mind that most people tap '4's in time with music, is it OK doing it like that - when you have a '1 times' and '4 times' button as well? (ie on '4 times' you get four wobbles to each press). That way you could get a '16s' effect when playing along to a drummer...
Would you really miss a 'speed' knob?
(BTW You can reset the speed by holding the tap button for 1 second...)
Also, if it did only sawtooth wave forms (ramp up and ramp down) but the depth, and the 'mark/space' ratio were adjustable (sound to no-sound ratio) that'd be OK, yes? After all, my Twin Reverb (sawtooth, ramp up) just has 'speed' and 'depth' controls, and muddles by OK somehow...
I'm re-doing the Minor Concussion pedal, and realise there's a whole other side to it... Though there are some limitations.
Whaddyathink?
  • ICBMICBM Frets: 74390
    Yes, I would really miss a speed knob - I would never buy any type of pedal where the only speed control was tap-tempo. It's not always convenient or the most useful way of setting speed. The 1/4 button is a good idea though.
    No, sawtooth-only is not OK. It needs to have a true square wave modulation setting as well - not simply "high depth", as some makers seem to think is what 'hard tremolo' means.
    To me, the point of a tremolo pedal is mostly to do more interesting and unusual types of tremolo than an amp, just like the point of a reverb pedal compared to amp reverb.
    Just my opinion of course, and quite possibly a minority one.
  • midiglitchmidiglitch Frets: 172
    edited September 2013
    Tap tempo tremolo is my main thing, so I'll bite.
    Personally I could cope without a speed knob, and I think I'd get used to that but it's pretty out there and
     I could see it putting people off.  I think some form of flashing led is pretty much essential so you know roughly what it's set to before you turn it on.
    Personally I don't need a 4x switch or whatever because I tap in at the speed I want it to go.  What the diamond tremolo that I use has, which is an absolute winner, is that the beat subdivision selector also affects the depth of the tremolo so you get a fast tremolo on top of a slow tremolo type thing. The effect is subtle  and perfectly locked in but it has a real nice throb to it, particularly on triplets.
    I think you could get away with having sawtooth and not sine or triangle but you really need to have a square wave available (as ICBM said), ideally full on to full off with depth controlling the ratio of time on to time off.
    The reverse sawtooth at full depth is a wonderful effect -check out the old "vox repeat percussion" to hear that - it's almost like a short heavy delay.  Incidentally someone on the old forum made me one but sadly it clips with my main guitar :(
    Finally, please do include a volume pot with some boost available because tremolo by its nature can give the impression of a volume drop and this has rendered some otherwise good pedals unusable for me.
  • I agree with icbm. I like the division idea though - electro harmonix do this on the memory boy deluxe, where you can tap tempo into a digital control unit where you can select subdivisions. It remains an analogue bbd circuit, though.
    As far as trem pedals go, I like choppy (as in, on-off-on stuff), as well as softer stuff (a la amp style). Anything extra is good, but I'd mostly use the hard square wave setting. It's not used much in metal, but a simply melody turns into an out and out ripping solo sound with that and modulated delay.
    However, kudos for being different. I like the subdivisions thing - I think 1 and 1/4 is limited, a triplet one as well would really complete the package.
  • The thing is, when this is on the '1 times' setting, it does that side-chain/ducking thing with the bass drum - makes the drums and guitar pump together, makes the guitar sound 'spring-loaded'! The tremelo is a bonus at the moment, but I'm trying to make more of it... Hence the questions (and the limitations).
    It's going to be weird, different - and limited from a tremelo perspective - but make sounds you can't get anywhere else.
    Will also work from a bass drum mic, or 'CV in' and have a 10 LED pulse meter on the top.
    This is the side-chaining bit...
    http://www.youtube.com/watch?v=hRNKINx5_Rs
    and tap tempo (with tempo correction)...
    http://www.youtube.com/watch?v=WFqNhWVGmEE
    Will check out Memory Boy Deluxe and Diamond Tremelo.
    What does 'hard tremelo' mean?
    Proper square wave modulation, no slope. With the depth on full it goes from full volume to off. The old Boss PN-2 used to be able to do that...
  • Oh - I love that! I have a custom-made non-optical tremelo that does that... Sounds severe, and keeps 'focus' at fast speeds - doesn't get blurry.
