QTX Hazer - FX1000 - This professional haze machine is the ultimate fine mist generator, radically different in its construction from a traditional haze machine.
This unit can quickly and smoothly develop a pre-determined level of haze and maintain it consistently. Control is achieved by 2-channel DMX or via the included remote control/timer.
This product has been specifically developed for professional installations and high-end DJ applications.
Features
2,400 CU Ft (68m³) per minute
True constant haze output
Variable output angle
Low fluid indicator
Timer output remote control included
Easy to transport and portable
2 Channel DMX (output level and fan speed)
Removable tank for easy maintenance
Recommended QTX Light High grade haze fluid for use with this machine
Specs
Power supply 230Vac, 50Hz
Haze output 2,400 CU Ft (68m³) / min
Warm up time 4 min (approx)
Power 400W
Tank capacity 1.6L
Dimensions 284 x 294 x 360mm
Weight 7.6kg
