Humungous Amp Sale Part 2
4) Orange PPC212 cabinet with Celestion V30s and Flightcase and Orange padded soft cover
This super cool cab is a great companion to any head - great punchy rock tones and bulletproof construction.
This was bought new in 2000 so it has British V30s rather than current models that are made in China I believe.
Its in great condition with a only a few minor tolex scratches and dirt. The flightcase has a couple locking casters.
YOURS FOR £400
5) SOLD Fender Supersonic 100W Head with flightcase
This brilliant head is extremely rare and a very limited edition with the red tolex and white front. Both of its channels are absolutely perfectly voiced with just the right number of features to make it super flexible but without making it overcomplex. Here's the website blurb:
"The Super-Sonic 100 head has a classic two-channel preamp with Vintage and Burn channels. The Vintage channel delivers tones based on legendary Fender favorites, with pre-gain tone controls and switchable voices for shimmering clean tones derived from vintage Fender Twin Reverb® and Showman® amps, and fat, punchy tone reminiscent of 1960s Bassman® amps. The Pre and Master Volume controls can be set for pure clean or slightly overdriven tones. The Burn channel ignites musical inspiration with overdrive flavors from bluesy to flame-throwing. Experiment with post-gain EQ and two-stage cascading preamp controls. Gain 1 provides edgy breakup and distortion while Gain 2 adds compression, thickness, and sustain. The Notch Tune feature lets you move the midrange notch for a variety of American and British flavors. The Super-Sonic 100 amp is capable of modern high-gain overdrive and sustain, but these characteristics can be fine tuned without masking the tonal character of your guitar. The Super-Sonic 100 head also contains impressive extras like the Arena/Club switch, which provides 25W output. The Damping control on the rear panel lets you select Normal, Loose, or Tight speaker response. And the all-new Fender Automatic Bias control (patent-pending) lets you easily set your output tubes to the recommended factory setting without a meter or tools. The bias can be set hotter or cooler if desired, and almost any mix of 6L6 power tubes will work."
Its seen some touring action cosmetically with some discoloration to the tolex but inside its in tip top condition with a complete new set of valves and just been fully serviced. It does not come with a footswitch.
YOURS FOR £500
