Hello
My Blackstar HT-1 Head is causing me a couple of concerns.
The main one being when it's fairly cranked the volume fluctuates up and down a bit - think a volume panner type effect. Could this be one of the valves on the way out?
The second - which I'm assuming isn't really a problem and more of a 'quirk' is when I'm using a particular drive pedal (in a Line 6 M13, Tube Driver sim) the amp seems to get really muddy and not make much sound as if it's stuggling to cope with the gain.
In respect of changing the tubes, I've used valve amps for nearly 20 years and have honestly never had to change a tube is this easy to do? especially on the HT-1 ?
Thank you in advance
