travel guitar
kinkin Frets: 1016
edited January 2015 in Guitar
1reaction image LOL 2reaction image Wow! 0reaction image Wisdom
  • ElwoodElwood Frets: 461
    Tried a couple and not gone one with them. Cheap construction and neck dive are the usual problems.
  • kinkin Frets: 1016
    http://img.photobucket.com/albums/v118/turquoisemoleeater/More Guitars/GrassRootsGR-PGG3TS-3_zps147ffa41.jpg
    the strap buttons seem well placed on these, that might help with the neck dive issue ( having said that they also have a full size headstock )
  • SassafrasSassafras Frets: 30357
    I used to have a little pignose guitar with a built in amp. It was fun and quite playable but I prefer a proper guitar, they're not a lot bigger or harder to carry around.
  • TTonyTTony Frets: 28434
    I've got one of these ...
    Bob Wiley's Ministar dispenses with the traditional guitar body, which adds little or noth...
    It's about as small as you can possibly make a guitar - the metal arm/leg rest pieces (which arent shown properly in the pic above) come off, so you're left with just the headstock and a piece of wood 24.5" (or whatever) long and fingerboard width!
    Plays surprisingly nicely and perfect if you must take a guitar on your travels and need to travel very lightly.
    Yes,that is small.Almost pocket sized.
    Will it fit inside a snooker cue case?
    How big is the snooker cue case ??
  • WezVWezV Frets: 17493
    edited January 2015
    mny worry is that the trem is so exposed.  Its either going to get knocked or tangled up in something.  travel guitars to me should be pretty stable so as you can pick them up and put them down with the minimum of fuss.
    having just got a thomann shorty start and mini RG I would go for something short scale for travel
    yep,i don't really see the need for the trem on a travel guitar. What's the mini rg like @WezV ?  I was thinking of getting one for my eleven year old daughter/ travel guitar for me.
  • JalapenoJalapeno Frets: 6462
    Steinberger and clones are ace.  Sling over shoulder or squeeze into Samsonite !
    Simples !
    Feedback
    have a look here
    http://thefretboard.co.uk/discussion/33073/2015-challenge-wezv-harley-benton-mini-guitars#latest
  • DrBobDrBob Frets: 3043
    Simples !
    This, in spades. You can lock the Trems out as well
  • A5D5E5A5D5E5 Frets: 307
    edited January 2015
    I've gone down the Steinberger route, but rather than the cricket bat Steinbergers, I've got the GU. The advantage of this is that it has a bolt on neck. I've put some threaded inserts into the neck so that I can put it on and take it off as many times as I like without loosening the joint. With the neck off, it will fit into a carry on bag.
  • XWulfhereXWulfhere Frets: 416
    I like those strat pickguard guitars. I make my own guitars and I also travel a lot for work, so I might have to give that a try :-)
    And you know what else? Those safety lids on bottles of sanatogen. There I am trying to get the lid off and along comes my six year old and says "there you are daddy" and it's off in a Jiffy. Someone's gonna get hurt.
  • I thought an acoustic was a travel guitar?
