So last night I decided to move one of my 2x12 cabs across the room, forgetting that it was actually connected to the amp sitting next to it on a different 2x12.
Clearly, I'm stupid.
The jack plate on the cab is cracked, that's no big deal, but when I pulled the the speaker cable out of the amp, it left the tip behind. The speaker jack sockets on the amp are the enclosed back plastic kind, so does anyone have any bright ideas for getting it out of there? The only one I've thought of so far is putting a dab of superglue on something long and thin, leaving it in there to dry then (hopefully) pulling the tip out with that. But since I've already established my own stupidity maybe someone else has a better idea.
Although I can just use the other speaker output for the time being, my concern is that if I leave it in for too long it might shift a bit and bridge the tip+ring terminals in the socket.
If need be I'll take the socket out, but it'd be nice to avoid that since the impedance switch, two sockets and OT secondaries are all bunched pretty tightly there.
Yes, it's one of those 'quick way of doing this' jobs!![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
Bandcamp
Spotify, Apple et al
Actually the Lanc, like most WWII combat aircraft, was pretty lightweight in its construction. It had a short intended service life (6 months was a long time to survive ops back then) and they had little knowledge of metal fatigue in aluminium alloys in those days. For obvious reasons, if an aircraft disappeared on a flight, they rarely knew if it was an engineering problem or enemy action.
My mum worked at A. V. Roe's in Chadderton during the war; the stories she told were eye opening.
Bandcamp
Sorry for the typo guys, I was trying to say my amp was build like Lancaster, the city.![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
>:D<
Bandcamp
Bandcamp
How far did you get with it?
Bandcamp
