So, much as I love the thing, the Studio is giving me some cause for concern and I would appreciate your thoughts.
The bottom E is too loud, acoustically and amplified. I have had the guitar setup, a couple of frets levelled, strings changed to a set of 9 - 42 from 9 - 46, action has been lowered to spec, and the neck pickup lowered a lot. I'm not sure that I like the sound so much now but anyway.
What has not changed is that the bottom E rings like a bell, resonates through the body and takes forever, really, to decay. I know a solid body should ring a bit but this is silly. My Dot is not as bad......
There is also a funny situation with the neck pickup whereby, if the volume is up a bit, there is a buzz which goes if you touch the strings. If you touch the actual pickup with your finger, the buzz gets very loud indeed.
Under some circumstances, if you push the tone controls in, the body actually amplifies the clunk and the guitar body rings loudly. Even better, laying the guitar across the arms of an armchair, so most of the body is suspended, gives rise to a microphonic effect where tapping the body causes all the strings to resonate through the amp. And it feeds back occasionally like my Dot but less musically.
I'm beginning to suspect the weight reduction is the problem, with the cavities being just right for the bottom E to resonate wildly. And the neck pickup issue is probably related too, as the bridge pickup seems OK.
Does this make sense? It is fucking annoying I have to say, is putting me off the guitar and is making me think take it back and do an exchange, either for a less ringy Studio or something else, but I don't really want to spend any more which is almost inevitable if all the Studios are the same.
I only have a few days to decide what to do and a refund is now out of the question.
Your thoughts please.
Save a cow. Eat a vegetarian.
Though there 'may' be a fix - but if you don't fully cure it before the deadline, you've lost the chance to get rid of a problem instrument at no loss to yourself.
The problem sounds a bizarre one - I'm struggling to imagine what the cause is - but actually, the 'real' cure is not having it in your possession anymore.
First, no question, there is an earthing problem which needs to be sorted out so they are fixing that.
Second, the ringing; yes they do all that don't they. I tried a fancy custom shop number in blue with a +£4000 price tag over my Studio and it was just the same. So, its a feature. Fine. I can live with that then and adapt to the sound.
AND, not turn it up loud when using my ID Core 10 which seems to be half the problem. The Harlequin is much better.
Even the luthier who did the setup for me thought it sounded perfectly normal for an LP so it's clearly me, not it.
And I love the way it feels and plays and really don't want to change it and to what, anyway, so I think it stays and I adapt .
