New Valves Needed?
IvisonGuitarsIvisonGuitars Frets: 6842
edited October 2013 in Amps tFB Trader
Do the assembled gentlemen recognise this and should I be sourcing a pair of new 6L6's?
http://www.ivisonguitars.com
(formerly miserneil)
  • ICBMICBM Frets: 72945
    Yes, and no.
    Beautiful blue glow!
    Ignore anything you may have read about this type of glow being a sign of bad valves, it's the exact opposite. I really have no idea where that myth came from.
  • IvisonGuitarsIvisonGuitars Frets: 6842
    Thanks @ICBM, that's good enough for me! :-)
    edited October 2013
    I probably should have said that it doesn't guarantee the valves are good - there can be other problems that don't show - just that by itself it indicates a valve with a good vacuum that's working correctly. The blue glow is actually caused by fluorescent minerals in the glass being bombarded by stray electrons.
    There is also a fainter blue glow inside the plate structure which indicates a tiny amount of gas in the valve and is also normal, but if it's excessive it can mean there's a problem.
    Pink or purple glow is always a problem and usually means the valve has seconds to live!
  • Yep, I concur...
    Get a pair of Chinese KT66 and watch a miniature version of the northern lights.
    I shouldn't worry, but I'd always have a spare set to hand.
    edited October 2013 tFB Trader
    Thanks @Van_Hayden, i'm going to get a set just in case. They've been in the amp since I purchased it 2nd hand (and I believe from new) so it's worth having a set in stock :-)
  • hotpickupshotpickups Frets: 1823
    What valves are you going for, for spares Neil ?
    Aye. Some blueness is fine. It's when they're boiling red that you've gotta watch out!!
