Good News Everyone, Axe FX II firmware
Handsome_ChrisHandsome_Chris Frets: 4780
edited November 2013 in Amps
FW 11.04 is out now.
Added speed (SPD) vs. position (POS) options to Modifier Auto-Engage parameters. The SPD options engage the effect when the controller changes more than 5% in any 20 ms interval (as before). The POS options engage the effect when the controller value is 5% greater than or less than the Off Value (depending upon whether the Off Value is less than or greater than 50% respectively). For example, setting the Auto-Engage to SLOW SPD will bypass the effect when the controller value is less than, say, 5% (default). To engage the effect the controller (foot pedal) must be moved more than 5% in a 20 ms interval. This requires that the pedal be moved somewhat rapidly and prevents the effect from engaging erroneously if the pedal droops. Setting the Auto-Engage to SPD POS will bypass the effect in the same manner but the effect will engage when the controller exceeds 10% (5% + 5%) regardless of the rate of change.
  • Handsome_ChrisHandsome_Chris Frets: 4780
    edited October 2013
    Added “Recto1 Org Nrml” amp model based on the “Normal” mode of an original two-channel Mesa Dual Rectifier.
    Added “Recto1 Red Mdrn” amp model based on the “Modern” mode of an original two-channel Mesa Dual Rectifier.
    Added “ODS-100 Lead 2” amp model. This is a “non-HRM” version of the ODS-100 Lead.
    Added “Bogfish Strato” and “Bogfish Brown” amp models based on a Bogner Fish preamp.
    Renamed all existing Recto models to “Recto2...” to differentiate between original two-channel models and newer three-channel models.
    Improved Room reverb algorithm.
    Fixed SYSEX_SET_DEFAULTS message not working properly (incorrectly changing X/Y state to X regardless of previous state).
    Fixed errant pointer causing problems with Global Blocks.
    Fixed problem editing IR names in TMA export and IR Capture Utility.
    Fixed wrong presence frequency in “Hipower” amp models.
    Fixed Arpeggiator indexing wrong notes when using Custom scale.
    Sorry @Si_ and @Rockmonster, no Mark V. :D
  • Si_Si_ Frets: 384
    edited October 2013
    My AxeFX is being taken off me on Saturday
  • RolandRoland Frets: 8836
    This time I am invoking my "two or three week's delay" policy.  Reverb and auto-engage look interesting, but I'll wait until the dust settles.
