Dulling finish question
I'm dulling the finish on a guitar body and just had some quick questions.
I've wetsanded with 1200 grit and 1500 grit. I've got the dullness I'm looking for, but when you look close-up the scratches, although light, are evident.
If I use a light abrasive substance and polish, like brasso or toothpaste, is this going to leave the dull appearance (naturally, minus scratches), or is it going to bring it back up to a high polish/gloss appearance?
  • CorvusCorvus Frets: 3012
    Starting 1500 would've been better, or 2000. If you hit it with that or 2500 it should improve though. You can get 3000 soft pads which leave a fine sheen (Trizact) but they're mostly sold in packs and a bit pricey.
    Toothpaste & brasso won't lose the scratches from the 1200 and will polish between those, kind of thing.
  • 5redlights5redlights Frets: 317
    edited March 2015
    Ah, that's pretty much different to everything I've read. I've seen a few people get good results with just wet sanding at 1000ish grit, finishing around 1500. I thought if you went much higher and then polished with a compound, you'd actually end up putting the gloss back in?
    Just to add I'm working on poly.
  • SassafrasSassafras Frets: 30322
    I'm not sure but I would've thought 0000 wire wool might serve your purpose.
    1200 can be pretty dang sharp, especially if it's a fresh piece. A 10-min soaking can help a little but still. When I flat fresh paint for polishing I usually start at 1200. It needs a good going-over with 1500 to rid the scratches from the 1200. But then the 2000 takes a lot less effort and you end up with a good even finish.
    The 3k pad isn't needed but it leaves a fine satin sheen. It's still a long way from full gloss but praps too shiney for people wanting more of a matt job (I use it because shows any missed scratches, saves compounding and then finding 'em after).
    The compounding then starts bringing it up to gloss.
    I wouldn't be happy with a 1000-sanded finish, but people like different things and internet pics don't show the fine detail in such things too well.
    Thanks, that's really helpful. I'll give it a good go with 1500 and finish with 2000.
  • WezVWezV Frets: 17000
    this.
    Somebody else was happy with the standard you have already achieved, you are not.  your standards must be higher
    from the stage you are at already i like to use 0000 liberon wire wool and briwax. - but that is more to get a worn semi-gloss than a satin
  • RoxRox Frets: 2147
    This will also depend on what the finish is too... presumably poly and nitro need different techniques?
  • OilCityPickupsOilCityPickups Frets: 11149
    I use Mirlon ...
    Poly/nitro, not really as far as sandpaper goes. Nitro varies a bit more but it's the same difference with the papers.
  • GagarynGagaryn Frets: 1553
    Micro mesh would probably do the job too, allow you to polish out the scratches but without bringing back the shine.
  • jd0272jd0272 Frets: 3867
    WezV;564165" said:
    this.
    Did one of mine (nitro) with 0000 wool and T-Cut, then went over it with polish and a cotton cloth. Came up lovely, just 'off the shine'.
  • Adam_MDAdam_MD Frets: 3421
    I used Liberon 0000 wire wool as well
    Original shiny finish
    Uploaded with Imgupr
    After the wire wool
    After some car polish
    All helpful comments, thanks. I found the wire wool to actually be a bit harsher than the wet paper, and would equate to around 800grit. I've wet-sanding up to 2000 grit and just polished with some brasso, and it is much better. Not quite a full satin, just a dulled finish that was the look I was going for. I'll get some pics up soon.
    I've also got a nitro gloss clear coat curing on a neck, so next week I'll just take the orange peel back a bit with 2000 grit wet sanding and polish with brasso again.
