Digital delays will do whatever they're programmed to do - they might have repeats that are perfectly clear, better than CD quality, for as long as you like. Or they might be designed to degrade like analogue, or anything else - modulation, filters, whatever the designers want from the pedal.
Bandcamp
Spotify, Apple et al
Delays also tend to be the stronger element of a lot of multi fx. For example the Zoom ms70 CDR is about £80 and will give you a whole range of delays to try plus chorus and reverb settings but it will need a bit more thought to use it than a 3 knob delay pedal will.
I have a Boss DD-6, which I prefer for "modern"-rock type sounds and longer delays. It also has a lot of features like warp and reverse, so is very versatile.
I also have a Visual Sound Axle Grease analogue delay, which I prefer for "Classic"-rock (IE Hendrix/Floyd) type sounds and shorter delays. More limited on the features, IE does straight delay with a bit of wobble.
Both are good, depending on what you want.
Analoge delay adds ambience
Digital delay adds special effects.
The axle grease sounds amazing if it's analogue you want, or the mxr carbon copy. If funds allowed, I'd get a deluxe memory boy from electro harmonix, which is bonkers - more of an analogue special effects pedal than ambience!
Overall I think I prefer digital; you can get the nice crisp repeats and you can also get the tape/analogue emulation and they sound perfectly good.
Also a Yamaha UD-Stomp, which is just epic.
Bandcamp
(b) Agreed. This is obviously an over-generalisation (not least when you consider the point we previously made about analogue-voiced digital pedals
