Matched Quad - JJ E34L valves
FarleyUKFarleyUK Frets: 2450
Selling a used-once matched quad set of awesome JJ E34L tubes. These run a little hotter than the standard EL34 tubes, so have a higher headroom.
Fully working, sound brilliant!
The JJ-Tesla E34L is a high grade EL34 valve that has some outstanding qualities.
The JJ valve is beautifully made with thick grade glass and features gold grid wire and uses high temperature alloy for the anode plates.
Sonically the JJ also provides excellent performance in audio as well as guitar amplifier situation.
In guitar amplifiers in a clean playing application the E34L produces a bright and vibrant top end. The Midrange is full and well balanced with a tight and well defined bass end.
In overdriven mode the JJ E34L produces a rich creamy overdriven sound with plenty of punch and bite.
£40 including postage to within the UK.
