SOLD: Matchless 1x12 Combo Cab In Silver Sparkle £100
jimmyguitarjimmyguitar Frets: 2479
edited May 2015 in Amps £
Here is a Matchless combo shell cabinet in rare silver sparkle tolex. It's unloaded but ready for a 12" speaker of your choice.
Can be used as an external cab or you can turn your existing matchless head into a combo.
It has holes drilled to accept either the larger 30w+ amps or the smaller 15w range so most Matchless amps should fit.
The light box was removed along with the old chassis.
This will look stunning with the correct amp fitted.
£150 cash on collection. I'm in Ascot but travel quite a bit so a meet up is poss within reason. Happy to post but it'll be extra £'s... Probably £30 ish within UK.
