SOLD:Wilkinson Tremolo for strat £25 delivered
Wilkinson WVP6CR SB Tremolo Bridge for Strat®, STEEL BLOCK, Vintage, WVP6 SB
Barely used, mint condition £25 delivered
Another brilliantly innovative design from Wilkinson featuring a range of improvements. The screw spacing is based on the Classic 56.4mm spacing, but with the elongated screw holes it increases the range of instruments that its suitable for. Will fit bodies with hole-spacing drilled from 54mm to 56.4mm (2 1/8" to 2 7/32")
Steel Block for greater sustain
Staggered String holes in BlockPush-In Tremolo Arm, with adjustable tension grub screwStainless-Steel SaddlesKnife-edge Screw Holes to eliminate string binding
http://i335.photobucket.com/albums/m447/thorpy6/6165E4D9-6B36-468B-BEA3-393AB04E020B.jpg
Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter:
@ThorpyFx | Facebook: ThorpyFx Ltd | Website:
www.thorpyfx.com
