Complete at last - Esquire Build - Aged finish haters look away
I have recently finished an Esquire build that I had every intention of keeping, It has been 3 years in the making, it's been a multitude of colours and the neck was an experimental piece for me to use new methods to check the lacquer. It's an Allparts soft V 7.25" radius with a Tusq Nut, the body is a guitar build job If I remember rightly, but it maybe a Mexican Tele(I had 4 that I  was working on at the same time and I've no idea which one was which)...It's got a Dimarzio Tru-Velvet pup in there, all the hardware has also been part of my experimental Hydrochloric Acid aging...The Loom was built by Marc at Mojo pickups and has a pair of Jookys signature PIO caps in it, I do still have to attach the jack socket in it, just haven't got around to doing it. Finish was done by staining the wood initially with iron oxide before a white primer was laid down and a Crescent Bronze Copper coat with 3 tinted clear coats and a few pure clears. Checked and aged not too over the top based on a few custom shop jobbies I found online.
0reaction image LOL 13reaction image Wow! 0reaction image Wisdom
  • DrBobDrBob Frets: 3020
    And that's the finish for my next build right there !
    Or maybe the Burgundy Mist ...
    Another awesome guitar Rich
    Nope, looking at it again, definitely the crescent bronze. Stunning colour
  • Excellent!
    wow man...that looks amazing!
  • jd0272jd0272 Frets: 3867
    Matey, that is pure porn. :)
  • impmannimpmann Frets: 12720
    Wow
  • Lovely work man.
    Using thus as inspiration for my thinline. Might have to message you at some point for tips, particularly gently ageing nickel hardware.
  • axisusaxisus Frets: 28354
    Very nice! Right up my street.
  • Yup, I'll ask.
    How did you age your hardware? I want very mild ageing, so whatever you've done but less of it.
    Currently, I've very gently scratched it up a little, polished it back up and then left a load of sweaty paw prints on it out in the garage. Wondering if I can speed things along, it doesn't take long to age nickel naturally but still...
  • RickydRickyd Frets: 149
    Very nice, especially loving that neck and headstock, superb.
  • lamf68lamf68 Frets: 851
    Hydrochloric acid in a tub, about 3mm in the bottom, then float another smaller tub inside that one and dump All The hardware inside the dry one. Lid on the whole thing and left it 24 hours before removing it and dropping the parts out into another tub with bicarbonate of soda and water mixed up in. Out of there to dry with a blast of wd40 on the tuners to expel as much moisture from the mechanism as possible and bobs your uncle... I tried checking the stuff every 20 minutes or so at first but it was like watching a kettle. I gave up and thought at worst I'd end up having to buy new parts..the bridge took a lot longer than the tuners as the nickel coating on the tuners was obviously thinner and 1 tuner lost a but too much of the coating but it still came out better than I'd imagined. I'm showing any old shit in the tub even now, anything metal is getting rammed in just for experimental purposes.
  • Cool, cheers mate. Was worried you'd say acid fumes, but hey ho. I'll probably do mine the old fashioned way - sweaty hands and lots of use. Nickel usually takes me a couple of months before it's dulled a bit, so I'll start there and see how it goes.
    If not, I'll try acid :D
  • GassageGassage Frets: 31120
    10/10
    Brilliant.
  • capo4thcapo4th Frets: 4437
    Great colour
    Rob, I've got another shade of copper which is more like a copper pipe if that makes sense, another stunning colour. I've bought so much of this powder ive enough for probably 100 bodies in each shade. 4 different shades of gold and proper Inca silver from powder. All a slight swine to work with but the finish is above anything ready mixed, I've never seen Metallics look so vibrant.
    lamf68;671042" said:
    [quote="DrBob;670382"]Nope, looking at it again, definitely the crescent bronze. Stunning colour
    [/quote]
    I totally get what you're saying and I think that 'Copper Pipe' sounds amazing. Only slight delay is that I'm currently working to earn the money to pay to get the body made but I won't get paid until the end of July so it will be a while..
    Whenever you're ready Rob. I'm away for most of July anyway so it'll time just nice.
  • WezVWezV Frets: 16945
    the body crazing looks really good
    have you tried ageing the metal particles in this style of finish yet... the way they go when  the lacquer wears away
    I am talking about the green you get on some copper danelectros and a lot of gold tops
    Wez, I've tried this mate, but to no great effect, I've managed to get my powders to go green a little but nothing as drastic as that, would you happen to know ho to do it?
  • WazmeisterWazmeister Frets: 9708
    @iamf68 - now THAT'S what a geetar should look like ! Stonking job mate !
