I've just bought (well committed to buy) a Bigsby B5 from fellow forum member
@stonevibe for my Telemaster project guitar. It wasn't until yesterday that I realised it won't work with the bridge I have installed (genius I know).
So it seems I have 2 choices:
1. File slots into the back of the current bridge so that strings pass straight through to the brass saddles.
2. Fit a Tune-O-Matic bridge.
At the moment I prefer the idea of fitting the Tune-O-Matic, but is this something that i'll fond hard to do? Would you advise against?
Plus i'd need to fill in the holes on the body from where the strings pass through and the screw holes that held the bridge in place. But it could all worth it it ends up looking anything like one of these:
Here's a pic of mine:
3. Buy a new ashtray and file the slots in that.
4. Buy a Vibramate V5-TEV
Nil Satis Nisi Optimum
Bigsby trems look more involved to me... I fear them but I want one, I tried a MIJ 62 tele reissue in sunburst with binding and it had a bigsby. Was a great guitar.... 500 quid new, and now 600 used
I had an original '65 Jaguar and a '69 factory Bigsby Tele, both were rock-solid for tuning. The main problem with Bigsbys is that they're usually fitted to guitars with wide headstocks and sharp nut angles, and/or floating bridges or fixed tune-o-matics, both of which cause trouble. A Bigsby Tele has neither.
What I meant was that *fitting* a Bigsby to a Tele is easier since you only have to drill, not rout
I wonder how hard it would be to fit one to my thinline... I don't like the vibramate look though so I'll be a dremel and a drill I fear.
Maybe another day...
Bigsbys on Thinlines are great, they restore some of the slight lack of 'solidity' in the sound compared to a standard Tele.
MY advice would be don't try fitting a Bigsby to a Tele at 10 in the morning with a raging hangover. No matter how sure you are you have it lined up, it won't be! ;-)
Of the two, I have to say I probably prefer the JM/Jag trem system, like ICBM I've never encountered any problem using them with the standard bridge - once it's properly set up they are rock solid, plus the ability to lock it to quickly move to drop D without messing with the other strings is handy. Only thing worth changing is the arm to the Staytrem version with a lined collet.
