Can anyone help with a curious problem I have with my volume pot please?
bignormbignorm Frets: 196
edited June 2015 in Making & Modding
Hi I've a EG that has recently been fitted with a 550k bare knuckle vol pot.
I love backing off the vol pot to clean up the gain and get a sort of chimey tone but since having the pot changed I've now got a curious problem
The volume suddenly cuts out near 1 or 2 so I can't do any violining anymore
I'm wondering if the treble bleed is the cause and if so what value should I change it to to get back the smooth taper?
  • ICBMICBM Frets: 73027
    Try removing the treble-pass cap (just undo one leg at this point) and see if it fixes it. Does the cap have a resistor in parallel with it too? If so that will definitely do that, so remove that too.
    You can use a different treble-pass network with a cap and a resistor in series - not the same values unfortunately! - which tends to do it much less.
    It may be the pot though, which is why it's worth testing it by removing the treble-pass first. Some pots don't have very good tapers, although I would expect a Bare Knuckle one not to be like that.
  • bignormbignorm Frets: 196
    edited July 2015
    I've used bare knuckle pots in the past and like the feel of the pot. I had a look and found there was a resistor inline with a capacitor.. So I snipped the leg of the resistor first and that solved it, obviously the resistor was messing with the taper.
    Nice one mate have a wisdom, that's the nice thing about this forum it's full of helpful knowledgable people.
    Cheers
