I dropped Irongear 'bucker-sized P90's in it and recently stuck a trapese tailpiece on it (seems to open up the tone & add a bit of 'reverb').
Also replaced the pots/caps with a kit from Axesrus - don't do what I did and wire up the tones so they work backwards and then not realise until I'd put it all back together again...
guitarcookie -
strangely mine has holes on body where a trapeze has been ! which wiring kit did you get from axerus ?
Also quick question ,will a dot fit in a jumbo acoustic padded soft case,like ritter type jobby ?
at moment its in old 12 string padded soft case,but is a bit roomy !
or if anyone has a suitable type case 'hard or soft', I have a generic black abs. no name, rectangle hard case (fits strats and Tele) bit battered ,but does the job ,can trade? based in Leeds
cheers Mark.
will have to see if the high output pickups grow on me?
the neck pickup is hotter than bridge:-(
which is unusual,for me anyway !
will see how I go. prob go for a humbucker size P90?
cheers Mark.
