Mini Zendrive
JalapenoJalapeno Frets: 6408
Anybody know of (or make) a Zendrive clone that is in a 1590A sized enclosure ?
I want one to complete my micro board
Feedback
  • monquixotemonquixote Frets: 17855
    Mooer do one it's the  "Rumble Drive"
  • JalapenoJalapeno Frets: 6408
    It's not really a ZenDrive (I have one)
    Feedback
    Interesting it must be a crap clone, cos I'm pretty sure it's supposed to be.
    Supposed to be a Dumble-ish pedal.  Not what I'm after.
    Feedback
  • frankusfrankus Frets: 4719
    the real issue with a 1590a zendrive is the 4 pot config requires 9mm alpha pots (so for a boot-eek maker) that's around £10 layout.
    the sabrotone veroboard will definitely fit in a 1590a ... but the pots oye!
    KOi Overdrive is looking like the thing ! :)
    Feedback
    I thought the Zen Drive was meant to be the "Dumble in a box"tm
    I wanted one for ages and wasn't that impressed when I got one.
    Can do RIAB, not a one trick pony -  it's a fairly subtle & creamy sound, in no way an ear splitter.
    Feedback
    £120?! kerazi!
    Cheaper than a Hermida original !
    £120 for mojo ? Bargain ;)
    Feedback
  • maraudermarauder Frets: 134
    Grind customs feng drive board fits in a 1590a and can be made as a Zen. Pain in the arse to do it though.
    Not a solderer in any way, shape or form ! ;)
    Feedback
    @Frankus - you like me probably missed it's Canadian dollars - so only (!) £109
    Feedback
    oh in that case boing!! +shipping ;)
  • nickb_boynickb_boy Frets: 1689
    The Koi does sound interesting. Check out this new clip:
    Will have to wait a while for me to try out as I've just done a decent deal on their Ten Cent Trem!
  • BadBoyKaneBadBoyKane Frets: 2
    edited August 2013
    Might be worth having a word over at diystompboxes, someone over there made a 1590A ZenDrive clone a couple years back:
    There might well be some layouts on the site somewhere (would be PCB layouts probably due to the size) if you can build yourself or get someone to build for you.
    Another DIY
    You can see the internals of a 1590A one here, 2nd pedal down:
    Grindcustoms do the PCB he used for the build for $8
    **EDIT**
    Just noticed I think he may be a member on this very site so you could get some info on him:
    I spotted the mini Zendrive from the 2nd link in this post in the bottom middle of his pic here:
    edited August 2013
    Yup, I've built one for me. However I tend not to build 1590A's for others. The main reasons are that they're an absolute sod to build, getting the 9mm pots reasonably has become difficult, you have to paint them if you use 9mm pots which isn't as robust as Envirotex, I can't use the decent stomps that I use in other builds in them as they don't fit, and finally they're not particularly stable when used in anger. Plus when you lay them out so you can actually hit them easily, you could have used a 1590Bs anyway.
    Essentially a lot of downsides and no upsides other than they're tiny. I could make one, but it'd end up being prohibitively expensive...
    edited August 2013
    KOi overdrive installed on my mini-board, getting trialled tonight at rehearsals.  Will report back.
    (Kevin's a nice bloke - didn't charge extra international shipping as it was the same from Canada to USA as to UK)
    http://koamps.weebly.com/koi-overdrive.html
    Feedback
    I'm interested to hear your opinion of the Koi. How long did yours take to arrive?
    I'm waiting on a Ten Cent Trem to drop through my door sometime soon I hope!
    edited August 2013
    4 days, very impressed.  Mine was in-stock, not made to order.
    Feedback
