Where to buy a body blank?
I want to get an Alder blank in order to build my first project guitar but struggling a bit to find somewhere to get one from.  The main issue is that I need something bigger than the standard Strat sized piece.  Doesn't have to be a huge amount bigger but I need something about 21" x 15".
How likely might a local timber merchant be to stock this kind of wood or am I limited to buying from a guitar wood specialist?
Any suggestions?
Cheers
  • You could ask Phil at www.guitar build.co.uk
  • WezVWezV Frets: 16917
    give David Dyke a call
    what you planning on making - 15" is quite wide and I doubt you will get a 1-piece
  • the_jaffathe_jaffa Frets: 1829
    Thanks guys, actually looking at it, you're right Wez, 15" is too wide, I'd need about 14".
    My plan is to replicate this Jag/Strat hybrid that John Squire used in the early 90s:
  • How close is that to a Jazz bass outline?
    It's pretty similar but not similar enough I think.  I did originally think it was a Jazz bass body but I've chatted with the guy who made the originals and it is a jaguar back end with Strat front.
    I'm keen to try making it as a project just need to find some wood now.  Looks like there are custom sized options on Guitarbuild so that might well be worth a shout
