Is this wiring possible
Before I waste my time trying to find it. 2 x humbuckers, have available 2 x push pull knobs 1 x mini toggle 1 x 3 way toggle. I'd like to be able to control volume and tone and coil split the selected pickup combination individually. Cheers
  • WezVWezV Frets: 16945
    dead easy
    the 2 humbuckers will be wired straight to the 3-way switch, then on to the volume and tone after the switch.  The coil tap wires from the pickups can be wired to each push/pull.
    No need for the mini toggle, but we would really need to know what sort of mini toggle you have as there are options such as a phase switch  or just a kill switch
  • SkodadadSkodadad Frets: 510
    It's just an on off type @wezv nothing fancy thought I may need it. Good to know it's easy enough as never split a dual humbucker setup before only single. Cheers mate
