What a major flipping annoyance ...
4114Effects4114Effects Frets: 3131
Just making a start on the turret board for my JTM 45. I normally build my own, but I thought I'd buy a pre assembled board to save some time.
Except it's just made more work. I bought the turret board and all the components from the same place, but not a single resistor is long enough to reach from one side of the board to the other. So now I'm going to have to stick another row of turrets in so I can actually assemble the thing. You'd think that buying all the parts from one place would ensure they've checked that they actually work together. Sigh.
Rant over.
  • paulnb57paulnb57 Frets: 3098
    edited December 2015
    Thats unfortunate.......understand your rantage.......I would be miffed too.....
  • ICBMICBM Frets: 73026
    I would be so miffed I would demand a refund as Not Fit For Purpose.
  • 4114Effects4114Effects Frets: 3131
    @ICBM can't tell if you're being sarcastic or not ... :-)
    I will probably mention it to the seller though, I had turrets spare so it's not too much of a problem. Someone new to amp building and buying this as a kit or similar would have a load of faffing about trying to make things fit. Not ideal.
  • SassafrasSassafras Frets: 30320
    Couldn't you send it back and get one that's properly laid out? Surely it can't be the only one they sell.
    @sassafras the turret board is fine, it's the resistors that are too short. Anyway, I want to build this over Christmas, so I'll just mod it. :-)
  • Modulus_AmpsModulus_Amps Frets: 2614
    Is this the board I supplied, It looks like one of mine anyway. The turret spacing on that board is already reduced by one hole for the resistors compared to the original 60's Marshall layout. This is because modern resistors have shorter leads.
    Have you seen the layout on my webpage?
    There are 2w Carbon film resistors available with longer leads but those ones should reach between the turret holes with a small bend over on each end.
    I'm not joking. A kit that can't be assembled with the parts supplied is not fit for purpose, unless it's specifically made clear that is the case.
