front-ported 2x12s: all SOLD
wired, baffled, unloaded, speaker screws in place
computer modelled by John Suhr when he worked at CAE to follow the EQ curve of a 4x12
1 remaining has feet for both vertical and horizontal use giving max options
Home use only, immaculate condition
ideal for carrying due recessed top handles and light weight
priced to sell:
£300
very small footprint cabs
when vertical, ideal for wet/dry or for adding power or projection to your set-up
I have one other, which I am keeping for such uses as they sound better than any other 2x12
if you prefer it loaded, I have some speakers available and will install
By 'spec' do you mean dimensions?
I'll have a look at my speaker pile and get back to you.
Peavey 5150s wired to 8ohms (these are no longer made)
Celestion Vintage 30s wired to 4, 8, or 16ohms
Celestion G12H75 Creambacks wired to 4 or 16ohms
Celestion G12M Greenbacks wired to 8ohms
all in excellent ungigged condition
If of interest, send me a PM
I'd love one (saw Steve Lukather using these), and he always sounds great live.
I have an Artisan cab set for 8 ohms. No way you could run this to 8 with creambacks or one v30 and one creamback?
If this was 8 I could use it as my primary cab, and then use both on occasion,
surprisingly light at 14kg
recessed side handles and solid back make them very easy to move
<weryth>
knight bump
