Rewire ... Lost control of tone knob, stuck on bassy sound
i had to rewire my guitar pickups and somehow I have lost any control with the tone knob, it just stays on the most bassy tone? All wires seem ok, and I can't have frazzled it. What am I likely to have done?
  • strtdvstrtdv Frets: 2587
    What are you rewiring? And is your pickup cavity shielded?
  • axisusaxisus Frets: 28389
    Paint shielding. Tele type controls but with two push pull switches.
    I had a similar issue with my SG when one of the capacitors was in contact with the copper shielding I have in the control cavity. Check no bare wire is touching the control plate, particularly if it's a tight squeeze in the control cavity
  • frankusfrankus Frets: 4719
    Sounds like a short is making the capacitor bleed to earth as if the wiper was all the round.
    See if the capacitor is touching earth
    edited January 2016
    Boy this is frustrating, the bloody thing! I have checked the pot and it is definitely working, tried a different capacitor, re-soldered joints. Nothing appears to be touching where it shouldn't be. The whole control area has been painted with shielding paint. Where the hell have I got a short????
  • Andyjr1515Andyjr1515 Frets: 3129
    edited January 2016
    Have you tried disconnecting the tone pot altogether? If so, does it sound back to normal? If so, it's definitely the pot or the capacitor or a wiring switcharound or a short. If it still sounds very bassy, then you have a different issue.
  • Paul_CPaul_C Frets: 8085
    Try undoing the nut on the tone pot and pulling it up so that it's not touching the shielding paint and see if that sorts it out - I put a John East preamp in my first bass build and it refused to work unless I isolated it from the shielding (masking tape) so you may be suffering a similar problem.
    How would one do that? Sounds like a thick question but can I just disconnect 1 wire to take it out of the circuit?
    I don't think that is the problem for three reasons, I have the whole tele control unit 'flipped out' of the guitar at the moment whilst trying to fix the problem
    edited January 2016
    ok - didn't notice it was a Tele ;)
  • Send pic
  • ICBMICBM Frets: 74396
    Is the cap between the volume pot and the tone pot, or between the tone pot and ground?
    Tone & ground. Was working fine 2 days ago!
    Re soldered with my new soldering iron tip (as mentioned in other thread), and all seems to be working again. Needed a decent solder joint and wasn't getting it with my knackered old iron
    That can't be it. A bad solder joint would cause an open circuit, which would leave the tone control not working at all. You would need a short to create a stuck-fully-down tone fault.
    So you've accidentally fixed what it was while you were working on what you thought it was :). The bad news is that the real fault may come back later. You can guess how I know this ;).
    Errrr .... You are right! It's gone again! Darned thing!
    First disconnect the tone control and check for sure that it is the problem - sometimes a 'tone down' sound can be caused by a partial short elsewhere.
    How does one disconnect? physically take off every wire and remove the pot or can one just remove one of the wires?
    Just disconnect the wire that runs from the volume pot to the tone pot - or the cap if thats how it's arranged. You only need to do it at one end. You don't have to remove the ground connection.
    If the tone pot is not connected to the signal path and you still get the problem, it's not the tone pot.
    Thanks, I'll give it a try next time it cuts out - been working all day!
