1. Wire each pickup to its volume control.
2. Take the signal from the volume pots to the switch
3. Connect the output from the switch to the tone control and from there to the output jack
4. Make sure all the components are correctly earthed.
5. Finally connect the middle wires from the humbucker pickup to the switch which connects then to earth when the pickup is split.
That's about it.
