This gives you a nice low action with very little effort. But it wears more than the other frets as tuning grinds it down.
I tend to use a SS fret for the zero, others go for higher fretwire.
Instagram
Both the Ss and higher fret solution introduce a slight compromise. The Ss brings in tonal variation between open and fretted strings, the higher fret compromises action. But you get a more reliable instrument
Instagram
I've replaced a couple with stainless but they still notched a bit though. OTOH one zero fret on an acoustic did make it from 1958 through to last year with standard skinny wire. I used slightly taller wire to emulate a typical nut slot height. Gretsch also do that but my Burns and Yams had same-wire ones originally.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
