Twin EL34 powered 26w Amp project
I fancy building one of these.
I have a suitable output transformer but can anyone suggest a power transformer? He uses a Weber W025130
But it's for 120v mains and I need a 240v version.
    You'll want the Weber W025130EU or the Weber W025130INT they both have 240v taps.
  • Modulus_AmpsModulus_Amps Frets: 2621
    Assuming you are using the lower voltage taps, in which case an AC30 Power transformer will get you in the region or a rocket/express type PT
    I am building a Cathode biased 2 x EL34 amp just now, but it will be mich higher gain than that video
  • FatfingersFatfingers Frets: 500
    Thanks. I didn't realise Weber did 240v transformers.
