'New' NOS Valvo EF86 - £30 Delivered
SunDevilSunDevil Frets: 511
I bought this to go in a Matchless Clubman, but didn't get on with the amp and returned it.
I don't have any other EF86 amps, so this is now surplus to requirements
As you can see, it's in genuine NOS condition, comes in the original grease-proof paper and rated exceptionally highly
Codes are D7B1, which as I understand it indicates Hamburg manufacture between '63-'67
I will ship in the original packaging, so it will be very secure
Apologies for the crappy pics - I need a macro lens!
  • SunDevilSunDevil Frets: 511
    Bump
  • babysnakebabysnake Frets: 21
    I have a matched quad of EL84 and some GT 12AX7 if you fancy a trade?
    Hi and thanks - I would, but my amp is JMI spec in the cathode resistor, so the only valves that I've found last more than an hour are the NOS Tung Sols - sounds epic though!
    Cheers
    Baz
    Bump
    Bump
    bump
    SunDevil said:
    bump
    I don't have a requirement for an EF86, but good ones are rare, and while you may have to wait for some time before you come across someone that needs one I hope you still have it to hand when that person pops up and says "Hey, I need an EF86". Good luck, and have patience.
    If I ever got my hands on a proper Radford HiFi amplifier, I'd need two.
    Bump
    Bulp
  • algroves1algroves1 Frets: 17
    Still got this?
    Hi @algroves1 - yep, still available
    Spring clearout Bump
