I currently have one of these Clarke woodworking benches in my garage...
https://www.machinemart.co.uk/p/workbench/
Had it for years, and barely used it. When I get my home workshop sorted out (major reworking), I plan to move it in and make use of it, at least as an interim thing. The rigidity is okay, but it's a bit lightweight - it tended to slide about the garage floor. I had planned to make some sort of brackets to clamp it to the garage wall, but my interest in general woodworking in the garage never took off and the brackets never happened.
Eventually, I'd like to make a better bench, both for guitar making and medium-sized woodwork stuff (like a wooden tool chest and other storage), at which point the Clarke will probably go back into the garage. I'm thinking of something of similar size - about 1500 x 500mm, although not sure of height yet. I don't have room for something much larger than that.
I'm generally happy with the arrangement of the vices on the Clarke bench, although I'm not convinced that they work all that well - never felt that confident in the bench dogs, for example, and they're a bit small for holding bits vertically (like a batten, end-up).
I've been looking at lots of benches online, and trying to work out what features are useful. Like a tool well - is it really needed, or just somewhere for crap to collect? There are a few designs for the tail vice - half width, full width, L-shaped, and some sort of slot affair with a dog in it. Do any of these stand out as better for guitar building? Some have a sliding deadman (panel on the front with holes for dogs), which looks better than the simple holes-in-leg on the Clarke (which only makes it useful for a certain minimum length of board).
What about under-bench storage? At first blush, it seems like a good idea, but I once put a board on the front of the Clarke and then wanted to get something out of the drawer and had to take the board off (not really a hassle, I guess, but something that might need to be planned around at times). What about clamping around the edges? If it has an apron, it'll get in the way of the clamps - is an apron (with dog holes) more useful than clamping space?
If you use a woodworking bench, what features do you find useful, and what don't really work?
Nomad
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
I made it because I could hear my dear old Dad saying "If you're going to be a carpenter why wouldn't you make your own wooden workbench!"
Thanks chaps. No wells, I see.
The Sjobergs look especially nice - really like the big vices and thick tops.
How do you find the heights? At the moment, I've been using my machine bench, which is about 940mm high, and I find that quite comfortable. I've got a lower bench (a Clarke metal cabinet with thick wooden top) that's 850mm high, and I never use it other than for doing stuff on a belt sander. I like the add-on height adjusting things that Sjobergs do - neat idea.
Went to the local wood place yesterday, and he has plenty of 3" thick rough sawn beech boards about 10" wide (and 8' long), so food for thought.
Nomad
