SOLD - Laney TT50H Head
AnglianAnglian Frets: 11
edited August 2016 in Amps £
The Laney TT50H is a 50-watt valve amplifier head that features 3 channels, Clean, Crunch, and Lead—each feature independent 3-band EQ, volume, bright switch, and reverb. The 2 gain channels feature a Modern switch which gives you super smooth response while the Lead channel features an additional Xpand and boost switch. Xpand breathes life back into your tone at high gain.
The power section features two independent footswitchable master volumes, allowing you to give yourself a boost whatever channel you are on.
All footswitchable features are fully MIDI switchable and the amp is equipped with MIDI in, MIDI thru, and MIDI out seven-pin connections which support phantom power.
Excellent condition, comes with footswitch & cable for channel select, reverb and master volume 2, also mains cable and cover.
Valves: 5 x TAD ECC83 and 2 x TAD EL34B-STR
Price: £300 £275
Payment: On-line bank transfer / Paypal gift
Pick up from North Cambridge near Ely.
