Which 3 way mini toggle switch for pedals?
A while ago I managed to break the lever of 3 way mini toggle switch on my Keeley Rat so I can't change modes any more. I think it should be a fairly easy replacement but I just can't tell what type of switch I need. Is it a 3pdt on-off-on?
  • Adam_MDAdam_MD Frets: 3421
    edited April 2016
    Can you post a picture? It's probably a spdt on/off/on
  • TTBZTTBZ Frets: 2957
    I haven't actually taken a look inside yet haha I'll open it up when I can and get a photo.
    Cool cheers mate will take a look inside soon as I can, hopefully an easy fix.
    The switch is the blue one with yellow wires running to it. Looks like that one you posted should work?
  • SporkySporky Frets: 29190
    I believe Adam_MD is correct; it'll be an SPDT on-off-on. I like the Apem ones best, they're made to a much higher standard that the others I've tried. Knitter are good too.
