Perfboard Purgatory
Guh.
Trying to build one of these:
Have made and populated the perfboard and wired up temporary input/output and 9v connections (and grounds).
Signal is passing through with little or no loss of volume compared to going direct (haven't bothered wiring up the switch and LED yet) but the all important tremolo effect is not present. Dwell knob acts as a volume control, speed knob and switch have no effect at all.
I've checked and double-checked my board against the diagram and everything appears to be in the right place. I've run a craft knife between the rows to cut any solder bridges. I've re-flowed all the solder joints that looked like they might be suspect.
No dice. More importantly, no tremolo. There's a guy in the comments thread on tagboardeffects who has the same problem, which makes me feel slightly less useless.
What next, electronics boffs?
  • english_bobenglish_bob Frets: 5221
    Found it. Had a resistor linking the wrong rows. One fiddly desoldering job later I've got me a working tremolo pedal. Yay me.
  • SporkySporky Frets: 29190
    Excellent.
    I hate perfboard. Really, really hate it. I'm consistently amazed that people manage to build things on it that work.
    Sporky said:
    Excellent.
    I can see why. I'm still an electronics ignoramus so I'm far safer with pre-fabbed PCBs but I fancied a crack at a fairly simple circuit for not a lot of money so I bought a kit from Bitsbox. Now wondering whether the extra ball-ache is worth the extra tenner in my pocket compared to getting a PCB kit from Fuzzdog.
