http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
Last time, I used ICBM 's sandpaper method and it gave a rolled edge on the board. I'll probably do this on all my build guitars from now on as it's so comfortable. You can sand across the fret, but it'll still need polishing so it's much faster to just mask all of the frets and masturb-er, rub up and down carefully. I used 800 grit I think, maybe 600. Again, wire wool the frets after to get them smooth and shiny
I prefer to use a sharpening stone, I have a small one that's perfect for it.
However a word of caution, wait a few more days. sometimes a guitar is kept in too dry an environment where the wood constricts, a bit more moisture soaked in and neck fattens up slightly pulling tang ends back into neck.
http://www.diy.com/nav/decor/decorating-supplies/sandpaper-abrasives/blocks___brushes/B-and-Q-Flexible-Contour-Sanding-Pads-Fine-Medium-10549035?skuId=11039567
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Instagram
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I bow to your experience, I only said that as after playing a guitar that had frets protruding, they were cut back by filing about a mm, only to find a few days later fret ends had disappeared inside neck by a couple of mm and strings were then catching on ends. Nowhere to go then except a refret.
Instagram
Football is rubbish.
