FS FT Diamond Phantom USA Built 100w Tube Head
Barry7000Barry7000 Frets: 57
Hey Guys
You don’t see these very often now do you?
Diamond Phantom 100w Head UK Voltage
It features a clean channel and two distinct high gain settings in Channel 2. The Diamond Amplification Phantom tube guitar amp head has a more traditional high gain structure. Take you favorite amp and inject steroids and decongestants into, and you have the Phantom. Channel 2 also features DA's signature dual volume/gain design. This feature gives the player the option of having two gain settings that are accessible on the fly.
The Phantom features DA's signature "low focus" switch on the rear panel. The low focus switch provides three positions--low, mid and high. The Phantom also features an effects loop. Just plug a cable into the effects send and the loop activates. The front panel features a master volume, which reads E. Return. When the loop is on, the E. Return knob acts as the amp's overall master.
Built using the highest quality components and construction. Every component was selected and tested for this head. It uses six 12AX7 preamp tubes and four EL34 tubes in its power stage. A hexagon pattern perforated metal grille made in 16-guage steel with a unique silver vein finish offers the Phantom eye-grabbing good looks.
Key Features are:
  • 100W
  • Two independent channels
  • Volume, Gain, Bass, Middle, Treble and Presence control on both channels
  • Dual Volume/Gain Channel 2
  • Rear panel low-frequency, three-position adjustment switch
  • Two button footswitch included for access to Ch1/2 or Ch2 A/B
  • Green LEDs
  • Independent LEDs indicated which volume/gain is active and if boost is engaged
  • Properly designed, tube-driven effects loop
  • Original User Guide
This amp is in perfect condition with 1 careful owner, always been looked after, no issues here
Im asking £1300 for this one, and I’m interested in trades.  No amps!!  Just guitars of the same value
The amp is based with me in Burnley where ideally it will be collected from.  not keen on shipping amps
Thanks for checking out my listing
https://scontent-lhr3-1.xx.fbcdn.net/t31.0-8/s720x720/13268252_10154244538879185_162693829999229642_o.jpg
