Posted a thread a while back on how I get these type of shots:
I've since moved house and don't have the luxury of a garage room or a wall I'd be happy to permanently leave them black background setup.
So, I had an idea to make a temporary one that would be easy to use whenever needed (also handy for pictures of my daughter of course
The parts needed:
1x Door
3x rolls of self adhesive 'velour' material from Wilko's (still waiting to be delivered)
Then these bits;
(Door hangers, hinge, screws/bolts, guitar hanger)
The idea being, the inside of the door will be black all the time, but the guitar hanger will only be deployed as needed
First step, mark out where to drill, I rested the hinge on the door hangers in situ to mark out where to drill on the hangers using the existing holes in the hinge. I then used one existing hole on the hinge for the guitar hanger, marked out where the second hole should go and drilled that.
I drilled the holes, bolted it all together and took off the extra material on the screws with a hacksaw, finishing off the sharp ends with a bastard file.
Here it is in place;
Testing with a bass;
Once the background material turns up next week, I'll cover the door, the hinge, the guitar hanger and modify the guitar hanger to remove the rubber.
I'll then do some sample shots to share, including the photoshop steps needed.
Dave.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
