Ever wondered what the cockpit of a SR-71 Blackbird looks like?
DesVegasDesVegas Frets: 4635
edited June 2016 in Off Topic
Well today is your lucky day.
The word is they are all clocks set to different timezones cos it goes so goddamn fast
«134
  • SimonCSimonC Frets: 1399
    Pfffffft, doesn't even have a cup holder.
  • JezWyndJezWynd Frets: 6175
    Compare to the Lancaster. Seems incredible that the Lanc had a single pilot seat considering the duration of flights and physical strength required to operate.
  • DesVegasDesVegas Frets: 4635
    ^Looks pretty beat up for a deep space vessel
  • JalapenoJalapeno Frets: 6417
    ^It's the ship that made the Kessel Run in less than twelve......  etc ;)
    Feedback
  • TheMarlinTheMarlin Frets: 8140
    It's amazing to think it was introduced in secret in 1966, an retired in 1999.  It makes you wonder what they are flying in secret today!
  • lasermonkeylasermonkey Frets: 1940
    Back in the days when I was a "Friend of Duxford", I got to attend some of their open cockpit events and sat on quite a few different aircraft. It's amazing just how cramped some of them are. Maybe the most claustrophobic was the EE Lightning. Very little room to move, plus little forward visibility. Imagine doing the best part of 1,500 mph like that!
    In comparison, the Spitfire was positively spacious, if not exactly ergonomically laid out.
    Clambering around inside the Lancaster and B-17 was quite tiring. Considering it was fairly warm at the time and I was unencumbered by a flying suit, plus I was on the ground and no one was shooting at me, the twenty or so minutes I spent in each fair wore me out! Getting over the main spar in the Lanc was fun and I managed to gash my leg on the B-17 upper turret mechanism. Imagine doing that for eight hours at -20°C with people flinging lumps of metal at you.
    Back to the SR-71- I saw one fly at a display at Alconbury, probably in 1982. From takeoff, the acceleration was incredible. I was amazed at how the pilot threw it around the sky too, especially considering those things are huge!
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • ChalkyChalky Frets: 6811
    Think your memory might be playing tricks on you - the SR-71 had a much lower power to weight ratio than the Lightning, never mind the F15/F16, and I'm pretty sure that handling even at low weights was limited to something like 3g, about half what the F15/F16 would repeatedly reach in their display.
    edited June 2016
    What I was getting at, but should have said was "for its size". I mean, it's about a third longer than a Lancaster! When you see one flying up close, it's very impressive.
    I've seen Lightning displays and never forgotten the usual end of display trick where they'd point the nose up and disappear in seconds.
    I said maybe.....
  • NeilNeil Frets: 3699
    I'd seen the Blackbird before at an open day at Mildenhall many years ago.
    I also remember climbing though the Lanc that had just come over from Oz (painted white) at Biggin and being amazed at how tight it all was as we made our way down it.
    Incredible what those blokes of Bomber Command put up with. As well as nightfighters and flak they had the freezing cold, darkness and cramp!
  • Axe_meisterAxe_meister Frets: 4700
    How different the cockpit would look today. It would all be little computer screens.
    I'd hate to see the plumbing behind the dash to feed all of those analoge instruments.
  • strtdvstrtdv Frets: 2508
    My favourite fact about the SR71 is that it leaks fuel on the ground as it's designed to expand as it heats up at extreme speed. I believe at full tilt it's around a foot longer than it is cold on the ground, which is the same amount that Concorde expanded during flight, and Concorde was twice as long to begin with!
  • bazxkrbazxkr Frets: 618
    Indeed...........fuel was pissing out of it on the ground very easily visible. By the time it got in the air it needed refuelling as was almost empty. IIRC it had to maintain nearly stalling speed to stay at the same speed as the air tanker refuelling it. So advanced for it's day. None ever got shot down cos they just accelerated away from the missile. Google the SR71 flypast can't remember the tower but a UK base. A few cadets shit themselves that day.
    IIRC it had to start the refuelling at height then descend gently as it got heavier.
  • GassageGassage Frets: 31148
    It wasn't THAT secret!
    I saw it at Farnborough in 1973.
  • DiscoStuDiscoStu Frets: 5601
    I saw its earlier incarnation, the A-12, on the USS Intrepid in New York. I expected it to be bigger!
    bazxkr;1095024" said:
    strtdv said:
    My favourite fact about the SR71 is that it leaks fuel on the ground as it's designed to expand as it heats up at extreme speed. I believe at full tilt it's around a foot longer than it is cold on the ground, which is the same amount that Concorde expanded during flight, and Concorde was twice as long to begin with!Indeed...........fuel was pissing out of it on the ground very easily visible. By the time it got in the air it needed refuelling as was almost empty. IIRC it had to maintain nearly stalling speed to stay at the same speed as the air tanker refuelling it. So advanced for it's day. None ever got shot down cos they just accelerated away from the missile. Google the SR71 flypast can't remember the tower but a UK base. A few cadets shit themselves that day.
    That SR71 flypast is a great story! Though I very much think the flying details have been exaggerated... ;)
  • bluechargeboybluechargeboy Frets: 1906
  • cacophonycacophony Frets: 385
    used to work on the lightnings, binbrook was my first posting not all that long before the lightning was phased out. used to be in a room with a bloke who worked on the sim. every night he`d go and open up the building and use his radio to talk to nerds from all over the world and i`d go with him and, as the flight sim was never totally powered down, i`d fly it. got quite a few hours on the lightning that way.
    a hell of an aircraft once it was airborn, an absolute ancient bag of nails on the ground though!.
  • RolandRoland Frets: 8848
    bazxkr said:!
    Didn't Gary Powers get shot down by a Mig with external rockets and specially built missiles?
    Roland said:
    bazxkr said:!
    That was a U2.
