FS Egnator Tweaker 15w Tube Valve Head ( Fender Vox & Marshall tones) - £225
Up for sale is a lightly used Egnator Tweaker, awesome little head selling as it doesn't get much use. Light home use only comes with the original box etc.
New these are around £330 so save yourself some money.
Powered by a pair of 6V6 power tubes, the TWEAKER will set the new standard for gigging micro amps. The gain, EQ and master sections each have a Tweaker switch providing a wide-range of tones from the ultra smooth and satisfying to fully over-saturated lead tones.
15 Watts All-Tube
2 x 6V6 Power Tubes
3 x 12AX7 Pre-amp Tubes
Master Volume, Gain and 3-Band EQ
Modern/Vintage Amp Voicing Switch
Buffered Effects Loop
Selectable AC, British and American Tone Controls
Clean/Hot Gain Selector
Tight & Bright Voicing Switches
100V / 115V / 230V Switchable
Output Power: 15watts RMS Cathode Biased
Input Impedance: 1meg Ohm
Output Impedance: 4 Ohms, 8 Ohms Or 16 Ohms Switch Selectable
Tubes: Two Egnater Premium Selected 12AX7Matched Pair Of Selected 6V6GTA
Vintage/Modern:+4db @ 120hz, +4db @ 3.6KHz
USA/AC/Brit: Selects American, V-X, British Tone Stack
Clean/Hot Switch: +9db Gain Boost
Tight Switch: -6db @ 180hz
Bright Switch: +8db @ 4khz Max
Dimensions: 14” (W) X 8” (D) X 7.5” (H)
