Do you leave the pedals engaged, but simply toggle them into the chain as a whole??? Could I use one to do this??
Main chain is just a neutral path single channel amp set relatively clean...
Button one --> add chorus to the chain only
Button two --> add distortion to the chain only
Button three --> add distortion, overdrive/boost and delay to the chain only
in it's simplest use case I would leave the pedals turn on.. then program Button 1 to include loop 1.. then program Button 2 to include loop 2.. and Button 3 to include 2&3&4 kind of things??
But it's awesome, it can also power your pedals by an isolated power supply.
Also pretty cheap
I went for the glab as I can choose how many loops go in the fx loop.
I only use one loop possibly 2
Delay and I'm getting a verb.
