SOLD: Morgan PR-12 1x12 Combo Reverb Black Sparkle
Selling my Morgan PR-12 combo in black sparkle tolex. It is based on a Princeton circuit but with upgraded parts and mods.
Extremely loud, relatively lightweight and compact, BEAUTIFUL reverb (sorry but I needed to shout that!) and lovely and warm when driven.
The black sparkle tolex appears to be an optional upgrade, I haven't seen another one like it. Under stage lighting it glistens like a Christmas tree!
£1000 posted. collection from Ascot Berks welcome too. Comes with padded cover.
https://i.imgur.com/TdAj40V.jpghttps://i.imgur.com/10erOEV.jpghttps://i.imgur.com/d4G4MIR.jpg"The Morgan PR12 is based around the small American 12W combo from the 60’s. It has been updated with a bigger power supply and tightened low end and utilizes a 12” celestion. This amp incorporates all of the mods I have been asked to do on those old 60s American amps to make them more usable for live performances. The PR12 starts with the classic black face tone and then beefs up the low end by giving the power supply of the amp more juice so that it doesn’t fart out like the originals. The reverb has also been modified to add a Dwell control. The Dwell control allows you to control the amount of decay in your reverb. This allows you to have a very high reverb mix without washing out your guitar tone. The bass and treble controls interact with each other to give you a wide range of tones. The cabinet is a specially designed fix baffle cab. The fixed baffle design allows the entire cab to resonate with the speaker giving it a much larger sound for such a small box. As with all Morgan Amps the PR12 LOVES pedals and works well with any pedalboard. The PR12 is small footprint grab and go combo that will cut through any mix and is loud enough to get over drummer. Handwired in the USA."
• Power: 12w Class A/B tube
• Hand-wired in the USA
• 2x 6V6 power tubes
• 3x 12AX7 preamp tubes
• 3 Spring tube driven reverb
• Volume, Treble, Bass, Reverb and Dwell Controls
• 1x8 ohm 1x16 ohm outputs
• Custom USA made Mercury Magnetics transformers
• Limited lifetime warranty
• Made in the U.S.A.
PRODUCT DIMENSIONS
• Dimensions: 10" (D) x 18" (W) x 20.75" (H)
• Weight: 38 lb.
thanks
